NetApp Knowledge Base
Unable to access SANtricity System Manager GUI due to keystore or truststore file
1,356
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E2800
  • E5700
  • SANtricity OS
Issue
  • Unable to access SANtricity System Manager GUI. Web page displays the error below:
This site can’t be reached
xx.xx.xx.xx refused to connect.
Try:
・checking the connection
・Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
  • /msw_data/logs/trace.log indicates error when the system tries to start web service
Example1:
Example1:INFO [main] c.l.a.w.s.WebServer [WebServer.java:851] [requestId=0, deviceId=N/A] Unable to start HTTP server
java.security.UnrecoverableKeyException: failed to decrypt safe contents entry: javax.crypto.BadPaddingException: Error finalising cipher data: pad block corrupted
 ... 11 common frames omitted
Wrapped by: java.io.IOException: keystore password was incorrect
 at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(PKCS12KeyStore.java:2108)
 at java.base/sun.security.util.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:243)
 at java.base/java.security.KeyStore.load(KeyStore.java:1479)
 at com.loem.aa.webserver.update.ChainedTrustManager.getTrustStore(ChainedTrustManager.java:341)
 at com.loem.aa.webserver.update.ChainedTrustManager.<init>(ChainedTrustManager.java:131)
 at com.loem.aa.webserver.server.WebServer.mkContextFactory(WebServer.java:1717)
 at com.loem.aa.webserver.server.WebServer.mkSslConnector(WebServer.java:1663)
 at com.loem.aa.webserver.server.WebServer.mkConnectors(WebServer.java:1653)
 at com.loem.aa.webserver.server.WebServer.startWeb(WebServer.java:1029)
 at com.loem.aa.webserver.server.WebServer.start(WebServer.java:847)
 at com.loem.aa.webserver.Main.main(Main.java:77)
Example2:
INFO [main] c.l.a.w.u.ChainedTrustManager [ChainedTrustManager.java:339] [requestId=0, deviceId=N/A] Loading the truststore: /msw_data/truststore
java.io.IOException: Invalid keystore format
        at java.base/sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:667)
        at java.base/sun.security.util.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:222)
New to NetApp?
