NetApp Knowledge Base
E-Series SANtricity OS and IOM firmware matrix for support of different drawer control modules
628
Visibility:
Votes:
1
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • Drawer Control Module (DCM)
  • Input Output Module (IOM) for expansion shelves
  • Drive Shelf Models: DE212c, DE224c and DE460c
Answer
Key Notes
  • Mixing of IOM models in the same expansion drive shelf is not possible. The same IOM models must be paired within a shelf for full redundancy.
  • Mixing of DCM models in the same drive shelf is possible.
  • All the IOM and DCM models require different versions of IOM firmware and SANtricity OS else they may not be recognized by the system. Adding these components to a live system running an earlier version may result in disruption.
  • IOM12G firmware is exclusive to E4000 controller’s onboard SAS expander and needs to be at listed version for an E4060 shelf to recognize a DCM3 drawer.
IOM Model IOM Firmware Version SANtricity OS release Supported DCM(s)
IOM12 0281 or earlier 11.70.3 or earlier Legacy DCM
0300 to 0311 11.70.4GA to 11.90R2 Legacy DCM and DCM2
0401 11.90R3 Legacy DCM, DCM2 and DCM3
IOM12B 0141 or earlier 11.90R2 or earlier Legacy DCM and DCM2
0202 11.90R3  Legacy DCM, DCM2 and DCM3
IOM12C 0103 11.90R3 Legacy DCM, DCM2 and DCM3
E4060 (Local Expander IOM12G) 0113 or earlier 11.90R2 or earlier Legacy DCM and DCM2
0201 11.90R3 Legacy DCM, DCM2 and DCM3
