NetApp Knowledge Base
E-Series EF Controller in lockdown due to unresponsive BMC
1,148
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series EF600
  • NetApp E-Series EF300
Issue
Controller goes offline and in lockdown and is unable to serve any data.
Recovery GURU may report:
  • Failure Entry 2: OFFLINE_CTL-Recovery Failure Type Code: 28
Event log may report:
  • The controller's BMC is unresponsive - Shelf 99, Bay <A or B>
If AutoSupport is enabled, one or more of the following errors may be report:
  • ECRFLT:E-Series Notification from <controller name> (Controller redundancy lost) CRITICAL
  • An additional ECRFLT:E-Series Notification from <controller name> (This controller's alternate is non-functional and is being heldiin reset) CRITICAL has been reported for this system
  • ECRFLT:E-Series Notification from <array name> (Write-back caching forcibly disabled) CRITICAL
  • EHWENC:E-Series Notification from <array name> (Entering invalid system configuration) CRITICAL
New to NetApp?
