NetApp Knowledge Base
What is path style vs virtual host style
3,526
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID
  • AWS
Answer
  • Virtual hosted style requests have the bucket as part of the subdomain instead of the URL path (see below for examples)
    • Virtual hosted style example: https://bucket_name.s3.testdomain.com/object_key
    • Path style example: https://s3.testdomain.com/bucket_name/object_key"
Virtual-hosted-style:
  • Uses a virtual-hosted-style URL to access the bucket.
  • Virtual hosted-style is now the default method for AWS S3.
  • StorageGRID and many applications still support path style, it is best practice to implement virtual hosted-style support.
  • Virtual-hosted-style URLs include the bucket name as part of the domain name.
  • If you choose to use a domain name instead, it is recommended to use the "Virtual Hosted-Style URL" for StorageGRID.
    • Example: https://bucket_name.s3.company.com/key-name
    • Example: bucket.domain.domain.domain
  • It can support wildcard DNS lookups as well
    • Example:  *.s3.company.com
  • Information over configuring virtual hosted style: Configure S3 endpoint domain names
  • Only populate the S3 endpoint domain page if virtual style is needed for the environment.
Path-style:
  • Use a path-style URL to access the bucket.
  • The "Path-Style URL" is the default URL style used by clients when configuring StorageGRID.
  • Path-style URLs include the bucket name at the end.
  • This style is used when you provide an IP address instead of a domain name for the Server name (FQDN) field.
  • Note: The path-style URL option is not recommended and will be deprecated in a future release of StorageGRID.
Additional Information
  • To make AWS s3 CLI generate pre-signed URLs that use virual style, run:
    • aws configure set s3.addressing_style virtual
