Is there a way to audit objects in a cloud storage pool and a StorageGRID storage pool
Applies to
- NetApp StorageGRID
- Cloud Storage Pool
Answer
Yes, the only option is to manually retrieve the UUIDs of objects and use the REST API to query their metadata. This metadata can then be analyzed to determine object associations.
There is currently no automated tool available to audit objects in the cloud storage pool hence its not feasible for large environments containing large number of objects.
Additional Information
N/A
