NetApp Knowledge Base
Is it possible to enable Multi-factor Authentication (MFA) for StorageGrid?
1,114
Visibility:
Votes:
1
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • Multi-Factor Authentication (MFA)
Answer
  • Yes, MFA can be enabled on StorageGRID via Single sign-on (SSO) functionality.
  • Once enabled, SSO can be extended at the identity provider (IdP) to enforce various forms of multi-factor authentication including biometric authentication, or access via and RSA token or similar encryption device.
  • StorageGRID supports the following SSO identity providers (IdP):
    • Active Directory Federation Service (AD FS)
    • Azure Active Directory (Azure AD)
    • PingFederate
  • Additional details about the identity provider requirements and configurations can be found at this page: Requirements and considerations for single sign-on.
Additional Information
