NetApp Knowledge Base
Why StorageGRID Unable to Communicate with Node alert did not trigger
29
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
hw
Last Updated:
Applies to
NetApp StorageGRID
Answer
The Unable to communicate with node alert looks for the following attributes from Prometheus.
  • (count(up != 1) without (job) > 0) - Checks if a node is unreachable or offline
  • unless on(instance) storagegrid_administratively_down == 1 - Checks if the node is administratively down
The administratively down attribute determines if the node being down is expected. The attribute is set during the following exceptions.
  • Placed into maintenance mode
  • Being decommissioned
  • Undergoing a clone operation
  • Powered offline from the BMC or physically
  • Shut down from CLI
If the administratively down attribute is true, the alert will not trigger.
Additional Information
additionalInformation_text
