NetApp Knowledge Base
Storagegrid upgrade pre-check warns open ports execution expired
24
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
StorageGRID
Issue
  • When running a StorageGRID precheck receive the error:
    • Open Ports Error while checking connectivity from LOAD_BALANCER_NODE_NAME to STORAGEGRID_NODE_NAME: execution expired
  • Reviewing the file /install/directory/check_open_ports.log you will see log output similar to the below:
    • E, [2026-03-11T16:30:11.297994 #3258171] ERROR -- : Thread error while running precheck from LOAD_BALANCER_NODE_NAME to STORAGEGRID_NODE_NAME
    • E, [2026-03-11T16:30:11.298083 #3258171] ERROR -- : execution expired (Timeout::Error)
    • E, [2026-03-11T16:30:11.298127 #3258171] ERROR -- :     /usr/local/lib/site_ruby/bycast/commands/remote-sh.rb:59:in `synchronize'
    • E, [2026-03-11T16:30:11.298158 #3258171] ERROR -- :     /usr/local/lib/site_ruby/bycast/commands/remote-sh.rb:59:in `call'
    • E, [2026-03-11T16:30:11.298188 #3258171] ERROR -- :     /var/local/install/upgrade-stage/prechecks/check_open_ports.rb:115:in `check_ldr_internal_s3_port'
    • E, [2026-03-11T16:30:11.298217 #3258171] ERROR -- :     /var/local/install/upgrade-stage/prechecks/check_open_ports.rb:59:in `block (3 levels) in check_node'
    • E, [2026-03-11T16:30:11.298247 #3258171] ERROR -- :     /usr/lib/ruby/3.1.0/timeout.rb:123:in `timeout'
    • E, [2026-03-11T16:30:11.298274 #3258171] ERROR -- :     /var/local/install/upgrade-stage/prechecks/check_open_ports.rb:58:in `block (2 levels) in check_node'
New to NetApp?
