NetApp Knowledge Base
Storage node reports CASA error and system log indicates a network issue at that time
230
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
StorageGRID 11.4
Issue
  • Storage node reports CASA error.
  • Cassandra service is still running.
  • nodetool status command from the target Storage node shows DN (down).
  • Bycast.log records the below message:
Example:
Jan 15 05:26:27 XXXX ADE: |21565833 0217996451 DDSM SQRT 2021-01-15T05:26:27.491683| WARNING  0206 DDSM: Possible error in Cassandra gossip detected. Node with IP x.x.x.x appears down.
  • system.log records the below message:
 Example:
WARN [InternalResponseStage:255] 2021-01-15 05:26:48,874 Gossiper.java (line 1168) Resetting connection pool to /x.x.x.x, too many failed echo attempts: 15.  This usually indicates a network issue.
  • The following dashboards (Support --> Metrics --> Cassandra Network Overview) shows nothing happened at that time range.
 “Missed Gossip Messages: Sender ”
 “Missed Gossip Messages: Recipient”
New to NetApp?
Scan to view the article on your device
