NetApp Knowledge Base
Storage Node down and unable to rebuild Cassandra
509
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
Issue
  • Storage node is offline more than 15 days
  • Cassandra service is in an 'Error' state
  • check-cassandra-rebuild script is unsuccessful with the following errors:
Warning: Unable to determine what address to replace. Using eth0 10.X.XX.XX instead.
warning: Command "etc/init.d/cassandra start" failed with result "starting cassandra … failed to start: entering error state." exit code 1". Failed to start cassandra service
  • StorageGRID /var/local/log/servermanager.log shows:
cassandra not started because it has been offline for longer than its 15 day grace period - rebuild cassandra
  • StorageGRID /var/local/log/system.log shows:
Exception encountered during startup
New to NetApp?
