One or more StorageGRID nodes appear 'blue' (state unknown) in NMS
Applies to
StorageGRID all versions
Issue
- One or more StorageGRID nodes appear 'blue' (state unknown) in the Network Management System (NMS).
- Logging in to the console of the affected nodes reveals that all the services are up, and none is in an error state.
- If there are two NMSs, one NMS might display the node 'blue', while the other displays a different status (for example, green, amber, or red).
