SnapCenter Upgrade failed with Error "SnapCenter Schema Creation failed"
Applies to
SnapCenter server 4.5/4.6
Issue
SnapCenter Upgrade failed with below Errors
Installation log
CreateDB: CustomAction1: Error!!!! dotMigrate return with failure
ERROR: SnapCenter Schema Creation failed. Check the DotMigrate logs in the Windows Temp folder for more details.
DotMigrage_MySQL_x.log
2022-09-06 09:59:45.583 Executing SQL script C:\Users\svc_pd_snapctr\AppData\Local\Temp\o3102hmv.ib2\4.6\4.6.3.0009_Remove_stale_bkpObjMap_entries_from_nsm_smoracle_database_metadata.sql
2022-09-06 10:29:47.308 Error: executing SQL script C:\Users\svc_pd_snapctr\AppData\Local\Temp\o3102hmv.ib2\4.6\4.6.3.0009_Remove_stale_bkpObjMap_entries_from_nsm_smoracle_database_metadata.sql
2022-09-06 10:29:47.308 Error: Lost connection to MySQL server during query
