NetApp Knowledge Base
Unable to upgrade the SQL host to SnapCenter 6.1 Plug-in
434
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter 6.1
  • SnapCenter Plug-in for SQL
Issue
  • When upgrading the host SQL servers to the new 6.1, the process fails immediately and does not create a Job in the Monitor.
  • An error in the \Program Files\NetApp\SnapCenter WebApp\App_Data\log\SnapManagerWeb.log file may show:
2025-02-11T14:26:36.6161341-05:00 ERROR SnapManagerWeb PID=[6760] TID=[12] Exception caught while invoking https://example.server.com:8145/SMCo...ce/GetHostInfo
(extra lines removed)
2025-02-11T14:26:36.6170086-05:00 ERROR SnapManagerWeb PID=[6760] TID=[12] Error getting host status bit: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
 ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception.
 ---> System.ComponentModel.Win32Exception (0x80090331): The client and server cannot communicate, because they do not possess a common algorithm.
New to NetApp?
