NetApp Knowledge Base
Task "NetApp Unmount Datastore" is stuck when detaching virtual disk with SCV
354
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for VMware vSphere (SCV) 4.1.1
Issue
  • When performing "Detach Virtual DIsk" with SCV, the task "NetApp Unmount Datastore" is stuck in vCenter Server.
Example:
  • aegis.log indicates that the disk was removed successfully.
Example:
DEBUG VSC com.netapp.aegis.vsphere.VirtualMachineService Detaching disk fileName [nfs01_vol1(XXXXXXXXX)] XXXXX/XXXXX_1-000001.vmdk and uuid XXXXXXXX-XXXX-XXXX-XXXXXXXXXXX
DEBUG VSC com.netapp.aegis.vsphere.VsphereService VsphereUtils: Monitoring Task ReconfigVM_Task
DEBUG VSC com.netapp.aegis.vsphere.VsphereService VsphereUtils:State=success(100%)
DEBUG VSC com.netapp.aegis.vsphere.VirtualMachineService Disk removed Successfully.
DEBUG VSC com.netapp.aegis.restore.VmdkRestoreManager Successfully detached the vmdk: [nfs01_vol1(XXXXXXXXX)] XXXXX/XXXXX_1-000001.vmdk
New to NetApp?
