NetApp Knowledge Base
Snapshots are deleted immediately after SnapCenter backup is run
1,392
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
 Applies to
  • SnapCenter Server (SC)
  • SnapCenter Plug-in for Exchange (SCE)
  • SnapCenter Plug-in for VMware vSphere (SCV)
  • SnapCenter plug-in for SQL (SCSQL)
Issue
  • Snapshots are automatically deleted by Data ONTAP immediately after a backup creates it
  • Error seen in the <installation_path>\Program Files\NetApp\SnapCenter\SMCore\log\SMCore_<id>.log:
ERROR SMCore_879223 PID=[3460] TID=[200] ErrorCode (-1), ErrorMessage (Unable to find Snapshot (snapshot_name) on volume (volume_name) from storage (SVM_name_or_IP_address))
  • For SCE, the error may look a little different
Activity 'Renaming VSS Snapshot' failed with error: Rename snapshot '{snapshot_name}' failed:  entry doesn't exist
.Failed in volume 'volume_name',  entry doesn't exist
  • The below error is logged in the EMS-LOG-FILE.GZ log
[ONTAP_NODE]: snap_helper: wafl.volume.snap.autoDelete:info]: Deleting Snapshot copy 'SNAPSHOT_NAME' in volume 'VOLUME_NAME' to recover storage
  • For SCV, the error may look like below
ERROR USDPRDCUSAPSCNTR --- [1738236591-1263] c.n.a.s.c.SnapManagerStorageServiceImpl  : [JobId:223] Mount Backup failed: Failed to create the volume clone.
Failure. job details: [ 1638400 ]: Failed to retrieve snapshot information. Reason: entry doesn't exist.
ERROR USDPRDCUSAPSCNTR --- [1738236591-1263] c.n.a.m.VmfsMountStrategy                : [JobId:223] Failed to create LUN clone <LUN Name> on volume svm0:<LUN Path> Failed to create the volume clone.
  • The below error is logged in the audit-m and mgwd log
[kern_audit:info:3589] [traceid:71c8bef2e2629e476d85a5d64fcedf05] 8503e80000014f8a :: cluster:ontapi :: 172.16.2.247:36426 :: svm0:admin :: <netapp version='1.7' xmlns='http://www.netapp.com/filer/admin' vfiler='svm0'><snapshot-multicreate>   <snapshot>snapshot name</snapshot>   <volume-names>     <volume-name>volume name</volume-name>   </volume-names> </snapshot-multicreate></netapp>  :: Pending:
[kern_mgwd:info:3589] 0x82c913000: 0: INFO: EMS::SNMP: snmpTransmitEvent called for event (name: wafl.volume.snap.autoDelete, seq_num: 144587), trap (type: 1, id: 656, data: Snapshot Autodelete: Deleting snapshot 'snapshot name' in volume 'volume name@vserver:9a0a45c4-fdaa-11ef-8514-d039' to recover storage.)
[kern_audit:info:3589] [traceid:f0e2bd8e60cf9b61a3ddafeb77f47785] 8503e80000014f93 :: cluster:http :: 172.16.2.247:35342 :: USYOTSAN000041:admin :: POST /api/private/cli/volume/clone : {"junction_active":true,"parent_snapshot":"snapshot name","parent_volume":"volume name","flexclone":"clone volume name","use_snaprestore_license":"true","vserver":"svm0","snaplock_type":"non-snaplock"} :: Error: Failed to retrieve snapshot information. Reason: entry doesn't exist
New to NetApp?
