NetApp Knowledge Base
SnapCenter backup failure with SetSnapshotLabel and ImportModule failed
109
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server
Issue
  • SnapCenter backup jobs fail with errors related to snapshot creation.
  • The job status is “Warning” or “Failed.”Key log output from SnapCenter SMCore job logs.
Error:Failed on 'DC1-xxx-xx':Activity 'Replicating to Secondary' failed with error: SetSnapshotLabel failed: 102, ImportModule failed for 'C:\\Program Files\\NetApp\\SnapCenter\\SMCore\\PSToolkit\\DataONTAP.dll'The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: The specified module 'C:\\Program Files\\NetApp\\SnapCenter\\SMCore\\PSToolkit\\DataONTAP.dll' was not loaded because no valid module file was found in any module directory.Unable to find SnapMirror policies for the extended data protection relationships. Snapmirror update failed with SDError(-1) - An error occurred while updating the mirrors.No Mirrors found!
New to NetApp?
