SnapCenter DB2 custom plugin deployment fails with message 'Error in invoking SCC RestEndpoint configureService'
Applies to
- SnapCenter 4.x
- DB2 custom plugin
- Linux host
Issue
After adding the Linux host, attempt to deploy DB2 custom plugin fails.
SnapCenter GUI shows the host's 'Overall Status' as Services Stopped.
Failed installation job log (SnapManagerWeb) entry:
2023-05-17T20:05:48.8174205+10:00 ERROR SnapManagerWeb_856439 PID=[4024] TID=[188] ErrorCode (-1), ErrorMessage (Error in invoking SCC RestEndpoint configureService : HTTP 404 Not Found)
2023-05-17T20:05:48.8174205+10:00 ERROR SnapManagerWeb_856439 PID=[4024] TID=[188] Update Config failed while installing sccore on host <hostname>
2023-05-17T20:05:48.9268006+10:00 ERROR SnapManagerWeb_856439 PID=[4024] TID=[188] Failed to install DB2 plug-in. Error: Failed to upload custom plug-in, error: HTTP ERROR 404 Not Found
URI: /PluginService/ImportCustomPlugin
STATUS: 404
MESSAGE: Not Found
SERVLET: null
