NetApp Knowledge Base
SCV restores fail when multiple clones of LUN are found
817
Visibility:
Votes:
2
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plugin for VMware vSphere (SCV)
Issue
  • SCV restores fail with "More than one clone of LUN with UUID:5c6c54f4-83dcd92a-ad89-0025b501a000 found. Aborting mount because this is not supported. Check and verify whether multiple clones of the LUN are present which are not yet resolved as VMFS datastores"
2020-04-10T10:27:51.0000160-05:00 DEBUG VSC com.netapp.aegis.vsphere.DatastoreService [JobId:XXXXX] DatastoreUtils: Invoking Rescan VMFS on ESX HOST <ESX hostname>
2020-04-10T10:28:04.0000170-05:00 DEBUG VSC com.netapp.aegis.vsphere.DatastoreService DatastoreUtils: Completed Rescan VMFS on ESX HOST <ESX hostname>
2020-04-10T10:28:04.0000170-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy vscDatastoretoMount size: 1
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Total number of unresolved volumes: 1
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Finding the matching Host Unresolved Volume
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Finding: Comparing original datastore UUID <UUID> with unresolved VMFS volume's UUID <UUID>
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Uuid Match Found for Host Unresolved volume: <UUID>
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Adding entry in the map
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Total Number of entries in DatastoreVolumeMap: 1
2020-04-10T10:28:24.0000101-05:00 DEBUG VSC com.netapp.aegis.mount.VmfsMountStrategy Total Number of Extents found for the volume is 2
2020-04-10T10:28:24.0000101-05:00 ERROR VSC com.netapp.aegis.mount.VmfsMountStrategy [JobId:XXXXX] More than one clone of LUN with UUID:<UUID> found. Aborting mount because this is not supported. Check and verify whether multiple clones of the LUN are present which are not yet resolved as VMFS datastores
2020-04-10T10:28:24.0000101-05:00 WARN  VSC com.netapp.aegis.mount.VmfsMountStrategy [JobId:XXXXX] Error during mounting datastore : []
New to NetApp?
