NetApp Knowledge Base
SCV fails to mount clone volume due to the SVM root volume with load-sharing mirror
441
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter plugin for VMware vSphere (SCV)
  • NetApp Data Broker (NDB)
  • NFS datastore
  • SVM root volume with load-sharing mirror (LSM) configuration
Issue
  • SCV fails to attach virtual disk.
  • SCV fails to mount backup.
  • vmcontrol_<job_id>.log shows the following error.
Example:
2020-11-03 10:19:48.103 DEBUG ndb01 --- [    Thread-1272] c.n.a.m.NfsMountStrategy                 : Mounting the NAS datastore using the HostDatastoreSystem
2020-11-03 10:19:48.209 ERROR ndb01 --- [    Thread-1272] c.n.a.m.NfsMountStrategy                 : vob.vmfs.nfs.mount.error.perm.denied::NFS mount 192.168.0.131:/Sc5d4f18fd-4b33-e5a4-bc36-fe471ec1b5bf failed: The mount request was denied by the NFS server. Check that the export exists and that the client is permitted to mount it.
com.netapp.nvpf.api.model.ApiException: vob.vmfs.nfs.mount.error.perm.denied::NFS mount 192.168.0.131:/Sc5d4f18fd-4b33-e5a4-bc36-fe471ec1b5bf failed: The mount request was denied by the NFS server. Check that the export exists and that the client is permitted to mount it.
 at com.netapp.aegis.mount.NfsMountStrategy.mountDatastoreToESXHost(NfsMountStrategy.java:426)
 at com.netapp.aegis.mount.NfsMountStrategy.mountDatastores(NfsMountStrategy.java:165)
 at com.netapp.aegis.mount.MountManager.mountBackup(MountManager.java:242)
 at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdksToVM(VmdkRestoreManager.java:270)
 at com.netapp.aegis.server.AegisApiServiceImpl$6.run(AegisApiServiceImpl.java:1053)
 at java.lang.Thread.run(Thread.java:748)
  • snapmirror.log of ONTAP shows the following error.
Example:
action=End status=Failure message=Load-sharing destination volume cluster2://svm2/svm2_root_lsm is current; a "snapmirror initialize" or "snapmirror update" will have no effect on such a volume. Use "snapmirror update-ls-set" to update the load-sharing set. source=cluster2://svm2/svm2_root destination=cluster2://svm2/svm2_root_lsm
New to NetApp?
