NetApp Knowledge Base
SCSQL Clone Failure due to Capacity Pool Size
31
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
  • Azure NetApp Files (ANF) with SMB shares
Issue
When cloning SQL databases using SnapCenter on Azure NetApp Files, the following error is observed in the SnapCenter GUI:
Failed to clone the volume <VOLUME_NAME>:Unable to complete the operation. The capacity pool size of 59373627899904 bytes is too small for the combined volume size of 59910498811904 bytes of the capacity pool. Make sure that the total size of all the volumes in the capacity pool does not exceed the size of the capacity pool.
New to NetApp?
