NetApp Knowledge Base
SCO restore failed with RMAN error ORA-07217 : sltln : environment variable cannot be evaluated
1,515
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • NetApp SnapCenter Plug-in for Oracle (SCO) 4.6
  • NetApp SnapCenter Server (SC) 4.6P1
  • NetApp ONTAP 9.X
  • Oracle Database 12c
  • Oracle Enterprise Linux (OEL) 7.9
Issue
When restoring a SCO backup, it failed with the error:
RMAN-03002: failure of catalog command at mm/dd/yyyy hh:mm:ss
ORA-07217: sltln: environment variable cannot be evaluated.
com.netapp.oracle.core.platform.rman.RmanException: ORACLE-00101: Error executing RMAN command: [CATALOG START WITH '/var/opt/snapcenter/sco/backup_mount/xxxx_xxxx_xxxxx_DAILY_xxxxxxxx_mm-dd-yyyy_hh.mm.ss.xxxx_1/instance_name/1/' NOPROMPT;]. The command returned: RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
at com.netapp.oracle.core.platform.rman.RmanResult.<init>(RmanResult.java:74)
at com.netapp.oracle.core.platform.rman.RmanExecutor.execute(RmanExecutor.java:141)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.lang.Thread.run(Thread.java:750)
New to NetApp?
