NetApp Knowledge Base
SCO clone mount error isMount operation failed with error Object reference not set
70
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plugin for Oracle Databases (SCO)
  • Azure NetApp Files (ANF)
Issue
SCO unable to mount clone disk to new host and fails with errors:
Azure.RequestFailedException: Unable to complete the operation. The capacity pool size of 1947292 bytes is too small for the combined volume size of 1978276 bytes of the capacity pool. Make sure that the total size of all the volumes in the capacity pool does not exceed the size of the capacity pool.
Status: 200 (OK)
ErrorCode: BadRequest
and
"Clone from backup 'netappBackup_04-30-2025_12_38_00_9201_0' Failed on 'controllerACME': Activity 'Cloning Resources' failed with error; Failed to clone resources, error isMount operation failed with error Object reference not set to an instance of an object"
New to NetApp?
