NetApp Knowledge Base
SCO: delete clone fails out after 25 minutes and is kept "Running"
52
Visibility:
Votes:
0
Category:
snapmanager-for-oracle
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for Oracle (SCO) 5.0P2
Issue
When attempting to delete an Oracle clone from the GUI (or otherwise), the process doesn't appear to stop.
The main web process (Job Updates), fails with the following error messages:
ERROR SnapManagerWeb_<JOB_ID> PID=[4140] TID=[292] WebException caught while invoking https://localhost:8145/SMCoreCloneService/DeleteClone
ERROR SnapManagerWeb_<JOB_ID> PID=[4140] TID=[292] WebException Encountered, Response null
ERROR SnapManagerWeb_<JOB_ID> PID=[4140] TID=[292] Exception in method: InvokeXML.
System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
   at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
Note: localhost:8145 is the SMCore running on the SnapCenter Server, and that Job log ends with:
DEBUG SMCore_<JOB_ID> PID=[5572] TID=[71] Basic: HTTPS URL : https://<LINUX_HOST_FQDN>:8145/SMCoreP...SCO/CanExecute
DEBUG SMCore_<JOB_ID> PID=[5572] TID=[71] Basic: Certificate Name: [CN=...
This is a call to the SPL service layer no the Oracle Linux (or AIX) Host, which, as the last action, appear to have just picked up the ORACLE_HOME setting through the oracle user:
DEBUG qtp1644754972-4137 c.n.c.e.AbstractShellExecutor - EXE-00000: Executing shell command:
        0:/bin/sh -c "su" "-" "oracle" "-c" "env"
        1:su - oracle -c env
        LD_LIBRARY_PATH=/common/oracle/product/19.0.0.0.2501/db/lib
        ORACLE_SID=ORASID
        ORACLE_BASE=/common/oracle/product/19.0.0.0.2501
(etc)
DEBUG qtp1644754972-4137 c.n.o.c.s.d.m.DatabaseMetadataService - Completed method  findDatabaseHome within 1.092213 seconds.
DEBUG qtp1644754972-4137 c.n.s.s.p.c.o.CloneValidationHelper - Checking if the ORACLE_HOME  /common/oracle/product/19.0.0.0.2404/db is valid
INFO  qtp1644754972-4137 c.n.p.s.c.DatabaseResource - SCO-LOG-1018: Calling database cache cleanup call
DEBUG qtp1644754972-4137 c.n.o.c.c.ObjectCache - Evict invoked on ObjectCache for key DatabaseContext [uniqueConfigurationId=...
New to NetApp?
