NetApp Knowledge Base
How to generate CA Certificate CSR file for SnapCenter
8,389
Visibility:
Votes:
4
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Server (SC)
  • The article covers how to generate signed SSL certificates using Microsoft Certreq
  • This article provides steps to:
    • Generate a Certificate Signing Request (CSR) and
    • Import the certificate that can be obtained from a Certificate Authority (CA) using the generated CSR
  • The process outlined ensures that the certificate has a private key associated with it.
Ensure to follow the whole procedure on the same server.
  • The Microsoft Certreq tool is available by default on a Windows Server 2008 R2 system. So, CSR can be generated.
Note: The tool uses a configuration file to generate a certificate request.
New to NetApp?
