NetApp Knowledge Base
How to check Dynamic Port Range for SnapCenter Plug-ins
299
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter
  • Dynamic Port Range
In order to deploy Plug-ins, SnapCenter will communicate with host over dedicated TCP ports, the requirements are documented in:
In some cases the ports might be changed by Internal Group Policy or by a command/registry.
You can manually check which ports are defined as Dynamic Port Range
New to NetApp?
