NetApp Knowledge Base
How does SCSQL retention really work?
3,414
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 4.5 and later
  • Microsoft SQL Server
Answer
Backup retention evaluation is part of the backup workflow, and retention is only evaluated when a backup has been completed successfully.
  1. SCSQL is designed to delete the following old backup components:
    • ONTAP volume snapshots
    • Backups of the .ldf SQL Transaction log files from the Host Log Directory (HLD), in the form of TRB files
  2. Retention is applied differently, depending on the 3 possible types of SCSQL Policies:
    • Full Backup
    • Full Backup + Log Backup
    • Log Backup only
  3. Here are the backup components whose deletion can be controlled by the users:
    • DATA: Number of Snapshots or number of days the Snapshots should be kept for the volumes hosting SQL Data and Log files (via UI or cmdlet)
    • LOG: Number or Days the TRB files should be kept in the HLD (via UI or cmdlet, by setting the Up to the Minute (UTM) value)
    • LOG_SNAPSHOT: Number or Days Snapshots should be kept for volumes hosting TRB files (only via a completely filled cmdlet)
  4. Here is when retention is applied by SCSQL:
    • DATA: During a Full Backup or Full Backup+Log Backup
    • LOG: During a Full Backup+Log Backup
    • LOG_SNAPSHOT: During Any type of Backup, however the number of Snapshots or days snapshots that are kept is the sum of LOG_SNAPSHOT values of all Policies associated with the Resource Group (RG) used for the backup.
      Example: With a value of 2 LOG_SNAPSHOT for FullBackup+LogBackup Policy and a value of 2 LOG_SNAPSHOT for LogBackup only, SCSQL will keep 4 Snapshots of the HLD volume.
  5. Get-SmPolicy output and when it is applied. The Get-SmPolicy output for a Full or Log policy contains a section which starts with Schedules, for example Weekly. Under that section, there are key values like:
    • BackupType: Data (there may be two, one for this schedule and one for None, which is the OnDemand backup), LOG and LOG_SNAPSHOT.
    • SchedulerType: Weekly, Daily, Hourly or None
    • RetentionCount: the number to be kept
    • RetentionDays: the number of days to be kept
  6. Which Policy triggers retention for what component:
    • The Full Backup policy triggers all BackupType retentions.
    • The Log Only BackupType triggers only the BackupType LOG_SNAPSHOT.
Additional Information
Example:
Full+Log Policy - Daily
BackupType Data Data LOG_SNAPSHOT LOG
SchedulerType None Daily None None
RetentionCount 8 8 2 3
RetentionDays 0 0 0 0
LogBackup Only Policy - Hourly
SchedulerType None Hourly None None
RetentionCount 7 7 2 7
A RG with the two policy defined above will result in the following:
Ontap Volume hosting .mdf files: max 8 snapshots per scheduled type, in this case only daily.
Ontap Volume hosting .ldf file: max 8 snapshots per schedule type, as per above.
Volume hosting HDL: TRB files in HDL volume: only at the time a full+log backup occurs, the number of TRB will be reduced to a max of 3
Snapshots in HDL volume: max 4 (2 as per the SC 4.5 default of the Log Policy + the 2 we set for the Full Policy with the Log_snapshot variable via the cmdlet);
Note: SCSQL 4.4 and lower had a different retention setting for HLD snapshots ( hard coded to 7 snapshots). Starting from SCSQL 4.5 it is changed to 2 snapshots.
