NetApp Knowledge Base
Does SCSQL work with Volume Shadow Copy Service and the Data ONTAP Hardware Provider?
38
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
  • Volume Shadow Copy Service (VSS)
  • Data ONTAP Hardware Provider (Navssprv)
Answer
  • VSS and the Navssprv  is not used in any part of the SCSQL backup process.
  • It uses native SQL commands to create the backup and then uses VDI (Virtual device interface) for communication between the SCSQL plug-in and SQL.
  • The Navssprv is not installed on the SQL server during the plug-in installation.
