NetApp Knowledge Base
DB2 SCC plug-in backup or discovery fails : database is in write suspension
102
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Custom Creator
  • DB2 Database
Issue
When trying to backup a DB2 database, the backup fails with the following error in the DB2_<JOB-NUMBER>.log:
ERROR  [pool-12-thread-1] 42 com.netapp.snapcenter.plugin.DB2.DB2Logger -SQL1552N  The command failed because write operations for the database are
suspended or are being suspended.
SQL1024N  A database connection does not exist.  SQLSTATE=08003
Explanation: There is no connection to a database. Other SQL statements cannot be processed unless an SQL CONNECT was previously executed.
New to NetApp?
