NetApp Knowledge Base
Can SnapCenter manage SVM-DR relationships?
1,034
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter 4.x - 6.x
  • SVM Disaster Recovery (SVM-DR)
Answer
SVM-DR is not supported with SnapCenter (see Release Notes, ONTAP features not supported)
Additional Information
The following error from ONTAP may be seen in the SnapCenter logs.  This shows that SVM-DR is in use:
Because the parent volume is unprotected in the Vserver DR relationship. If volume requires Vserver DR protection, protect the parent volume first using the "volume modify -vserver-dr-protection protected" command. Otherwise, to create a clone without protection, specify the "-vserver-dr-protection unprotected" parameter
