NetApp Knowledge Base
CSNAPC-989: SnapCenter fails to connect an existing LUN to a host when the LUN has no file system.
287
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Issue
Connect Disk wizard shows Failed - Failed to connect disk No disk is found on all nodes when SnapCenter tries to connect an existing LUN that has no file system to a host.
  • * When creating a new LUN outside of SC, SC fails to connect it due to the following error:
         Failed - Failed to connect disk No disk is found on all nodes.
  • The same error can come from the command line with Connect-SdStorage (with or without --SharedDisk) on the actual Windows
         Host: Connect-SdStorage : Failed to connect disk No disk is found on all nodes
  • SCW Job Logs (C:\Program Files\NetApp\SnapCenter\SnapCenter Plug-in for Microsoft Windows\job_logs show lines like the following.
         Example:
     2020-02-12T11:40:10.6716065+00:00 Error SDW PID=[XXXX] TID=[XXXX] Error: Failed to get partition information from disk on node <PLUGIN HOST>
     2020-02-12T11:40:10.6716065+00:00 Verbose SDW PID=[XXXX] TID=[XXXX] Error: Failed to get partition information from disk on node <PLUGIN HOST>   at SnapDrive.Nsf.Core.Host.PartitionManager.<>c__DisplayClass13.<ConnectDisk>b__d(String node)
  • When use SC GUI Hosts => Disks => Choose Host => Connect the job fails at the Creating Windows file system stage with error:
         Failed to connect disk. No disk found on all nodes
New to NetApp?
