NetApp Knowledge Base
CSNAPC-11991: Mysql service fails during linking of HA pair of secondary server
43
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
When adding the partner node to a SnapCenter HA MySQL cluster the MySQL service crashes on the partner node and fails to add the node to the HA cluster.
MySQL fails during HA pair linking on the secondary server with SQL syntax errors during replication configuration. Reported error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'MASTER TO MASTER_HOST = '<ipaddress>', MASTER_USER ='root', MASTER_PASSWORD = '' at line 1
New to NetApp?
