CSNAPC-11923: RFE: allow for a shared disk in an AG SQL Cluster to be used as Log Directory from the GUI
Issue
In the Configure Log Directory dialog, the GUI does not allow you to select a shared LUN based disk (iSCSI/FCP) for each of the nodes, or select the AG Group in the FCI Instance to be able to select the shared disk there:
It only works properly for an AG Setup when having a dedicated disk for the Log Directory for each of the nodes, which is then, also properly shown on re-entry of the function.
For MSCS setup it works for the FCI Instance to define a shared disk path, or a CIFS UNC path for each of the nodes to the same volume (or qtree).
