AIQ support for data mismatch or queries regarding various components
Applies to
- ActiveIQ DIgital Advisor (AIQDA)
- ONTAP Clusters
Issue
- Issues with different components about AIQDA
- Some common things are:
- Some or all clusters/nodes are not visible in AIQDA
- Different/extra clusters are visible which are not managed by a particular account
- Reports/Upgrade advisor not available or not working as expected with all the required data
- Repeated entries for nodes with different details at different rows
- Need to add a new user or remove old users from the customer organization
- Support end dates not reflected correctly
