NetApp Knowledge Base
mgmtgwd.certificate.expired or mgmtgwd.certificate.expiring for AIQUM client certificate
4,995
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM)
  • ONTAP 9
Issue
  • ONTAP reports ERROR mgmtgwd.certificate.expired or ERROR mgmtgwd.certificate.expiring every day
    • mgmtgwd.certificate.expired: A digital certificate with Fully Qualified Domain Name (FQDN) <AIQUM_SYSTEM_ID>, Serial Number <SERIAL_NO>, Certificate Authority '<AIQUM_SYSTEM_ID>' and type client for Vserver <CLUSTER_SVM> has expired.
    • mgmtgwd.certificate.expiring: A digital certificate with Fully Qualified Domain Name (FQDN) <AIQUM_SYSTEM_ID>, Serial Number <SERIAL_NO>, Certificate Authority '<AIQUM_SYSTEM_ID>' and type client for Vserver <CLUSTER_SVM> will expire in the next NN day(s).
  • certificate show -type client command of ONTAP indicates that the client certificate installed by AIQUM for EMS subscription has expired
cluster1::> certificate show -type client
  (security certificate show)
Vserver    Serial Number   Certificate Name                       Type
cluster1   2B5E4C41        f9a179e6-091b-4325-8fe1-59d5e6e9fdd1   client
       Certificate Authority: f9a179e6-091b-4325-8fe1-59d5e6e9fdd1
             Expiration Date: Tue Aug 29 21:05:19 2023
  • Deleting the certificate in System Manager fails:
The certificate could not be removed due to the following conflicts: The certificate issued by "xxxxxxxxxxxxxxx" with serial number "xxxxxxx" is in use by the rest-api EMS destination "xxxxxxxxxxx" and cannot be removed.
Notes:
  • EMS subscription still works on AIQUM even after the client certificate expiration on the already added clusters.
  • However, a new cluster addition fails.
New to NetApp?
