NetApp Knowledge Base
CAIQUM-8859: AIQUM acquisition via REST fails triggering DuplicateKeyException cascade and REST errors across all clusters
395
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Issue
  • Active IQ Unified Manager (AIQUM) cluster collections fail when Cloud Agent collection is enabled.
  • AIQUM acquisition through Representational State Transfer (REST) with Cloud Agent enabled fails with DuplicateKeyException.
  • Performance graphs display flat lines; no new performance data is collected.
  • The Acquisition Unit (AU) log (au.log) shows a high rate of HTTP 500 errors from the server.
  • ocumserver.log includes:
ERROR [oncommand]org.springframework.jms.listener.DefaultMessageListenerContainer#1-1 [c.n.i.s.r.dao.AcquisitionInfoDao] Data Acquistion Save exception: org.springframework.dao.DuplicateKeyException: PreparedStatementCallback; SQL [INSERT INTO opm.acquisition_info (time,success,clusterId,analysisDuration,collectionDuration,msgRcvTime,isHistorical) VALUES (?,?,?,?,?,?,?)]; (conn=41092) Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY'; nested exception is java.sql.SQLIntegrityConstraintViolationException: (conn=41092) Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY' [...]
Caused by: java.sql.SQLIntegrityConstraintViolationException: (conn=41092) Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY' [...]
Caused by: org.mariadb.jdbc.internal.util.exceptions.MariaDbSqlException: Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY' [...]
Caused by: java.sql.SQLException: Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY' [...]
  • A timestamped DuplicateKeyException entry can also appear in ocumserver.log:
2025-11-20 07:56:11,503 ERROR [oncommand] [org.springframework.jms.listener.DefaultMessageListenerContainer#1-1] [c.n.i.s.r.dao.AcquisitionInfoDao] Data Acquistion Save exception: org.springframework.dao.DuplicateKeyException: PreparedStatementCallback; SQL [INSERT INTO opm.acquisition_info (time,success,clusterId,analysisDuration,collectionDuration,msgRcvTime,isHistorical) VALUES (?,?,?,?,?,?,?)]; (conn=41092) Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY'; nested exception is java.sql.SQLIntegrityConstraintViolationException: (conn=41092) Duplicate entry '1763639667703-47135' for key 'acquisition_info.PRIMARY' [...]
[Cannot invoke "com.onaro.sanscreen.acquisition.netappschema.netappdata.Volume.setHardwareEncrypted(java.lang.Boolean)" because "flexgroup" is null]
  • Additional DuplicateKeyException errors may appear for other tables, including netapp_performance.update_history and multiple sample_* tables.
New to NetApp?
