NetApp Knowledge Base
ClusterSwitchConnectionDegraded Alert after Power Maintenance
61
Visibility:
not set
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • * Event Messaging System (EMS)
  • * Cluster Switches
Issue
After power maintenance, all nodes were reporting
"ClusterSwitchConnectionDegraded_Alert":
Thu Nov 20 22:43:00 -0300 [NODE01: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: Total Packet Loss - Ping failures detected between NODE01_clus1 ( 169.254.168.1 ) on NODE01 and NODE08_clus2 ( 169.254.168.30 ) on NODE08
Also "SwitchIslIfDownWarn_Alert":
Fri Nov 21 21:23:27 -0300 [NODE08: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIslIfDownWarn_Alert , Alerting Resource = Cluster-sw01/Slot: 0 Port: 22 25G - Level raised by monitor ethernet-switch_x000D_
Fri Nov 21 21:23:27 -0300 [NODE08: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIslIfDownWarn_Alert , Alerting Resource = Cluster-sw01/Slot: 0 Port: 24 25G - Level raised by monitor ethernet-switch_x000D_
Fri Nov 21 21:23:28 -0300 [NODE08: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIslIfDownWarn_Alert , Alerting Resource = Cluster-sw01/ Link Aggregate 1 raised by monitor ethernet-switch
New to NetApp?
