Disable or remove the array pair in SRM fails with "Array pair is in use by one or more protection groups"
Applies to
- SRM versions including 8.x and 9.x
- OTV 9.13.x
- Vcenter 8.0.x
Issue
While removing an Storage Cluster from SRM the below error is observed:
Error was encountered when attempting to disable/remove the array pair in SRM due to an existing protection group.Operation Failed Unable to remove array pair "cluster_name:svm_name'. Array pair is in use by one or more protection groups.Operation ID: 3ad06xxx-9ea0-41d6-bf8e-9795e1xxx
