CVE 2025 1861 PHP vulnerability in ONTAP 9
Applies to
- PR needed for??[CONTAP-435586] CVE-2025-1861 - PHP vulnerability in ONTAP 9 -
- Jira - ngage
- [https://jira.ngage.netapp.com/browse...ssue-tabpanel]
Issue
PHP has released a Security Advisory and patches for one or more CVEs. Your
product has been identified as using PHP based on Blackduck data.
Evaluation of your product is required within 72 hours to determine if the
vulnerable code is present and the product exposed. This information may be
distributed in a public security advisory prior to patches being released.
Corrective actions will be determined after the analysis.
The Severity is based on the CVSS mapping to BURT. More information is available
at: https://security.eng.netapp.com/docs...nal-procedures
Contact ng-psirt@netapp.com with any questions.
VULNERABILITY INFORMATION:
https://nvd.nist.gov/vuln/detail/CVE-2025-1861
[https://nam04.safelinks.protection.o...3D&reserved=0]
https://access.redhat.com/security/cve/CVE-2025-1861
https://security-tracker.debian.org/.../CVE-2025-1861
https://github.com/php/php-src/secur...52jp-hrpf-2jff
Note: the online version of the advisory may be updated with additional details
over time.
Known Affected Versions:
PHP versions prior to 8.1.32, prior to 8.2.28, prior to 8.3.19, and prior to
8.4.5
Fixed Versions:
PHP versions 8.1.32, 8.2.28, 8.3.19, and 8.4.5
Please check the provided links in the vulnerability information for further
details.
CVE-2025-1861
CVSS Score: 6.3 (MEDIUM)
(CVSS:4.0/AV:N/AC:L/AT[https://jira.ngage.netapp.com/images...SC:N/SI:N/SA:N)
NVD: In PHP from 8.1.* before 8.1.32, from 8.2.* before 8.2.28, from 8.3.*
before 8.3.19, from 8.4.* before 8.4.5, when parsing HTTP redirect in the
response to an HTTP request, there is currently limit on the location value size
caused by limited size of the location buffer to 1024. However as per RFC9110,
the limit is recommended to be 8000. This may lead to incorrect URL truncation
and redirecting to a wrong location.
Impact: Successful exploitation of this vulnerability could lead to disclosure
of sensitive information, addition or modification of data, or Denial of Service
(DoS).
Please use the following format to document the analysis and paste it into a new
comment below:
Analysis performed by: (username)
CVE: CVE-2025-1861
Exploitable: (YES/NO)
Assessment Summary: (description of how conclusion was drawn)
Mitigation: (If available)
