Data Infrastructure Insights Acquisition Unit install/upgrade Resolution Guide
- 3,733
- Visibility:
- Public
- Votes:
- 3
- Category:
- data-infrastructure-insights
- Specialty:
- ds_dii
- Last Updated:
Applies to
- Data Infrastructure Insights (DII) (formerly Cloud Insights)
- Acquisition Unit (AU) installation/upgrade
Solutions
This Resolution Guide is intended to provide guidance on known issues related to installation or upgrade of DII Acquisition Unit (AU)
| Description | Link |
Ensure the Acquisition Unit Host operating system meets minimum requirements |
Acquisition Unit installation minimum requirements |
| Insufficient memory after AU upgrade | Data Infrastructure Insights Acquisition Service on Linux host fails to start due to insufficient memory after AU upgrade |
Special characters in proxy credentials not supported. |
Some proxies attempt to perform TLS/SSL inspection by impersonating DII web sites with digital certificates not generated from NetApp. |
Data Infrastructure Insights Acquisition Unit fails to connect for new install |
Some firewalls may not allow the use of wildcard rules. |
Java is used during AU installation |
DII and the Acquisition Unit are not able to make changes to the vault storing the keys used to encrypt and decrypt data collector passwords |
Data Infrastructure Insights data collectors polling error indicates the password cannot be decrypted after re-installing an Acquisition Unit |
Additional Information
How to collect logs for a Data Infrastructure Insights Acquisition Unit Server issue
