NetApp Knowledge Base
Global File Cache: Will rename or delete be seen by Edge sync?
184
Visibility:
Votes:
0
Category:
global-file-cache
Specialty:
ds_vc
Last Updated:
Applies to
  • Global File Cache (GFC)
  • Edge
  • Edge sync
Answer
  • The renaming or deletion of files will not be seen or picked up by Edge sync.
  • Edge sync is not designed to do so, and does not behave like a clustered file system.
Additional Information
additionalInformation_text
