NetApp Knowledge Base
Global File Cache: How to configure metadata Edge sync
105
Visibility:
Votes:
1
Category:
global-file-cache
Specialty:
bluexp
Last Updated:
Applies to
  • Global File Cache (GFC)
  • Edge
  • Metadata Edge Sync
  • How to configure Metadata Edge sync.
  • This KB will assume you plan on adding  the cordinator to one of the Edges you are enabling metadata Edge sync.
  • The Coordinator role could be placed on a Core
New to NetApp?
Scan to view the article on your device
