NetApp Knowledge Base
AFF-A320 is missing a path to one module on shelf NS224NSM100
172
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A320
  • NS224
Issue
  • Node missing path to shelf module in storage check-cables output. Example:
cluster::> storage check-cables
[Error: DualPathToNSM] There are two ports cabled from node "node_name" to topmodule (A) on Shelf with SN serial_number:
        Port e0b on node is connected to port e0b of top module (A) on Shelf with SN serial_number.
        Port e0e on node is connected to port e0a of top module (A) on Shelf with SN serial_number.
One of these cables should be removed.
[Error: MissingRedundantPath] Node "node_name" is missing a path to bottom module (B) on Shelf with SN serial_number.
New to NetApp?
