NetApp Knowledge Base
Unable to add cluster switch to monitoring due to duplicate IP address
225
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • FAS and AFF Systems
  • Cluster Switches
  • ONTAP 9
Issue
  • Adding the switch to monitoring fails with a timeout error:
cluster1::> system switch ethernet create -device clustersw1 -address 135.xx.xx.36 -snmp-version SNMPv2c -community cshm1! -model OTHER -type cluster-network -is-monitoring-enabled-admin true
Error: SNMP validation request timed out. Verify that the "-community-or-username" value is valid.
  • Ping to switch IP from node management LIF works.
cluster1::> network ping -lif node1_mgmt -vserver svm1 -destination 135.xx.xx.36
135.xx.xx.36 is alive
  • Snmpwalks from all nodes to switch intermittently timeout but works on partner switch.
New to NetApp?
