Multiple breakout ports fail to link up on Cisco Nexus 9336
Applies to
- Cisco Nexus 9336 Cluster Network switch
- RCF 1.8
- Breakout ports (4x10Gb/s)
Issue
- When using multiple 10Gb/s breakout links on a Nexus 9336, some links fail to come up
# show int status
Port Name Status Vlan Duplex Speed Type
Eth1/10 -- intFailEr trunk auto auto QSFP-40G-SR4
- Switch logs shows
Sufficient free entries are not available in TCAM bank
2022 Nov 21 23:05:21.598 Switch %ACLQOS-SLOT1-4-ACLQOS_OVER_THRESHOLD: Inst 1 Tcam 0 Bank 1's (Ingress L2 QOS [ing-l2-qos]) usage has reached its threshold
2022 Nov 21 23:30:10.018 Switch %ACLQOS-SLOT1-2-ACLQOS_OOTR: Tcam resource exhausted: Ingress L2 QOS [ing-l2-qos]
2022 Nov 21 23:30:10.028 Switch %ETHPORT-5-IF_SEQ_ERROR: Error ("Sufficient free entries are not available in TCAM bank") communicating with MTS_SAP_IPQOS_MGR for opcode MTS_OPC_ETHPM_PORT_BRINGUP (RID_PORT: Ethernet1/10)
2022 Nov 21 23:30:10.165 Switch %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet1/10 is down (Error disabled. Reason:Sufficient free entries are not available in TCAM bank)
