NetApp Knowledge Base
Brocade SFP reports Laser_Flt error due to faulty switch end sfp
6,657
Visibility:
Votes:
3
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade Fabric OS (FOS)
  • Brocade Fibre Channel (FC) switch
Issue
  • In switchshow port status is Laser_Flt
Index Slot Port Address Media  Speed        State    Proto
--Truncated--
20    1   20   701400   id    N16       Laser_Flt   FC
  • sfpshow output shows Tx as -inf and Rx in optimal range
Port 41:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 6801001200000000 8,16,32_Gbps SM lw Long_dist
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-1000486-01
Vendor Rev:  B
Temperature: 31      Centigrade
Current:     0.000   mAmps
Voltage:     3333.7  mVolts
RX Power:    -0.7    dBm (843.9uW)
TX Power:    -inf    dBm (0.0   uW)
  • portshow output shows the following-
portshow 1
portDisableReason: None
portCFlags: 0x1
portFlags: 0x4441
PRESENT U_PORT LED FAULT
LocalSwcFlags: 0x0
portType: 27.0
POD Port: Port is licensed
portState: 2 Offline
Protocol: FC
portPhys: 3 Laser_Flt
portScn: 2 Offline
port generation number: 76
state transition count: 18
  • Laser_Flt” state with Tx showing as -inf indicate that switch SFP is faulty
  • In order to further isolate this issue, try to reseat the sfp and check the status.
  • In case the port encounters same error again, proceed with the solution.
New to NetApp?
