NetApp Knowledge Base
Continual link resets (LR) occurring against Brocade switch port
7,339
Visibility:
Votes:
9
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade SAN switch.
Issue
  • Link resets on one port are reported:
2020/09/01-09:22:48 (CET), [C5-1014], 2001, CHASSIS | PORT 0/13, WARNING, BrocadeG720,  Link Reset on Port S0,P13(52) vc_no=0 crd(s)lost=5 auto trigger.
  • Continual link resets (LR) reported by MAPS on port # as indicated in errdump -a:
2020/09/01-14:54:34, [MAPS-1003], 796, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 2], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
2020/09/01-15:16:53, [LOG-1000], 798, FID 128, INFO, brocade_switch, Previous message repeated 2 time(s).
2020/09/01-15:20:34, [MAPS-1003], 799, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 2], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
2020/09/01-15:46:53, [LOG-1000], 802, FID 128, INFO, brocade_switch, Previous message repeated 3 time(s).
2020/09/01-15:46:58, [MAPS-1003], 803, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 4], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
2020/09/01-15:56:10, [MAPS-1003], 804, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 2], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
2020/09/01-16:01:22, [MAPS-1003], 805, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 4], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
2020/09/01-16:16:53, [LOG-1000], 806, FID 128, INFO, brocade_switch, Previous message repeated 1 time(s).
2020/09/01-16:23:40, [MAPS-1003], 807, FID 128, WARNING, brocade_switch, onpom_fc0, F-Port 13, Condition=ALL_F_PORTS(LR/min>=1), Current Value:[LR, 4], RuleName=CNLV_CMPLNT_LR, Dashboard Category=Port Health.
  • Under Fabriclog, could see port is flapping.
08:39:49.865779 SCN LR_PORT(0);g=0x24e4 LR_IN               D2,P0  D2,P0  13    NA
08:39:57.801578 SCN LR_PORT(0);g=0x24e4 LR_IN               D2,P0  D2,P0  13    NA
08:40:10.095012 SCN LR_PORT(0);g=0x24e4 LR_IN               D2,P0  D2,P0  13    NA
08:40:22.120959 SCN LR_PORT(0);g=0x24e4 LR_IN               D2,P0  D2,P0  13    NA
08:40:23.031030 *Removing all nodes from port               D2,P0  D2,P0  13    NA
08:53:26.644103 *Removing all nodes from port               D2,P0  D2,P0  13    NA
08:53:26.644295 SCN Port F_PORT                             D2,P0  D2,P0  13    NA
10:09:04.749379 SCN LR_PORT(0);g=0x27be LR_IN               D2,P0  D2,P0  144   NA
  • Verifying porterrshow reports excessive link fail counters :
          frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy  c3timeout    pcs    uncor
       tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig                  tx    rx     err    err
376:  298.7k 501.9k   0      0      0      0      0      0      0      0      9.9k   0      0      0      0      0      0      0      0
  • Interrupts, lli, proc_rqrd, lr_in, lr_out, ols_in, ols_out increasing in portshow:
portshow 13
portDisableReason: None
portCFlags: 0x1
portFlags: 0x24b03     PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
LocalSwcFlags: 0x0
portType:  26.0
POD Port: Port is licensed
portState: 1    Online
Protocol: FC
portPhys:  6    In_Sync      portScn:   32    F_Port
port generation number:    93268
state transition count:    92939
portId:    0a0d00
portIfId:    43020034
portWwn:   20:0d:88:94:71:b1:69:c0
portWwn of device(s) connected:
    21:00:00:24:ff:1d:8c:e2
16b Area list:
Distance:  normal
portSpeed: N16Gbps
FEC: Inactive
Credit Recovery: Inactive
Aoq: Inactive
FAA: Inactive
F_Trunk: Inactive
LE domain: 0
Peer beacon: Off
FC Fastwrite: OFF
Interrupts:        9909       Link_failure: 3          Frjt:         0
Unknown:           0          Loss_of_sync: 0          Fbsy:         0
Lli:               9909       Loss_of_sig:  0
Proc_rqrd:         211621     Protocol_err: 0
Timed_out:         0          Invalid_word: 0
Tx_unavail:        0          Invalid_crc:  0
Delim_err:         0          Address_err:  0
Lr_in:             4914       Ols_in:       4877
Lr_out:            4877       Ols_out:      4914
  • sfpshow 13
Port 13:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 6804404000000000 8,16,32_Gbps M5 sw Short_dist
Encoding:    6    64B66B
Baud Rate:   280  (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u (OM2):  3    (units 10 meters)
Length 50u (OM3):  7    (units 10 meters)
Length 62.5u:0    (units 10 meters)
Length 50u (OM4):  10   (units 10 meters)
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-1000333-01
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     083a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      112
BR Min:      0
Serial No:   JAF419030000RAD
Date Code:   190116
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x0
Pwr On Time: 1.15 years (10052 hours)
E-Wrap Control: 0
O-Wrap Control: 0
Alarm flags[0,1] = 0x5, 0x0
Warn Flags[0,1] = 0x5, 0x0
Temperature: 58      Centigrade
Current:     6.524   mAmps
Voltage:     3345.4  mVolts
RX Power:    -1.7    dBm (675.3uW) HIGHER THAN TX BELOW
TX Power:    -2.1    dBm (621.2 uW)
  • Below steps can be followed to isolate the problem:
    • Remove, clean, and reseat cable and SFPs for the connection. [NOTE:  This will include FC Patch Panels / Crossovers if applicable.  Please verify physical fabric if connection is straight through LC-LC, or otherwise.]
    • If issue persists after re-seat, change FC patch panel connection (if applicable).
    • If issue persists, replace cable(s) and swap or replace SFPs for switch and distant end device, and re-assess.
    • If above steps do not resolve link resets, please proceed with "Solution" section.
Show AI Tools
New to NetApp?
