NetApp Knowledge Base
Cisco UCS FI ports fail to show in devicelogin --show output
530
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade Switches
  • FOS 8.2.1
  • MAPS
  • Cisco UCS FI
Issue
  • Starting from FOS 8.2.1, there is a MAPS feature which allows the switch to keep track of Cisco UCS FI ports and the number of NPIV devices logged in on each port.
  • Additionally, this feature also allowed dynamic redistribution of NPIV logs across Cisco UCS FI uplinks. For more information on how re-balance feature works, watch this YouTube video from Brocade - Brocade FOS Automatically Rebalance UCS NPIV logins
  • With this issue, FOS fails to recognize Cisco UCS FI ports, which limits the functionality of NPIV re-balance feature by running command  devicelogin --rebalance
Example:
In this scenario, the number of initiators/NPIV is split across 4 ports, but only 2 ports are getting listed in the devicelogin --show
  • In the switchshow output, NPIV devices listed as expected.
switch:admin>switchshow:
switchName:    switch
<output truncated for brevity>
Index Slot Port Address Media  Speed        State    Proto
204    9   28   14cc00   id    N16      Online      FC  F-Port  1 N Port + 33 NPIV public
221   10   29   14dd00   id    N16      Online      FC  F-Port  1 N Port + 33 NPIV public
284    4   44   149480   id    N16      Online      FC  F-Port  1 N Port + 32 NPIV public
267    3   43   148380   id    N16      Online      FC  F-Port  1 N Port + 33 NPIV public
  • In the devicelogin --show output, ports 9/28 and 10/29 are listed, however ports 4/44 and 3/43 are missing under "Ports" column for Node WWN 20:01:00:de:fb:b6:64:c1
switch:admin> devicelogin --show
Node WWN                |State           |Ports Count |Ports (Number of devices) |
20:01:00:de:fb:1f:0a:81 |BALANCED        |2           |6/27(50), 5/26(50)        |
20:01:00:de:fb:b6:64:c1 |BALANCED        |4           |9/28(34), 10/29(34)       |
New to NetApp?
