NetApp Knowledge Base
How to change SSH ciphers or MAC algorithms on Brocade FOS
6,816
Visibility:
Votes:
4
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade FOS v7.4.0 and above
Security scanner application may report Fabric OS (FOS) vulnerability - 'Deprecated SSH Cryptographic Settings' or 'SSH Weak MAC Algorithms Enabled' along with following messages:
  • The remote SSH server is configured to allow weak encryption algorithms or no algorithm at all.
  • The remote SSH Server Supports Weak Key Exchange Algorithms.
  • The remote SSH Server Supports diffie-hellman-group1-sha1.
  • The remote SSH server is configured to use the Arcfour stream cipher or no cipher at all.
  • The remote SSH server is configured to allow MD5 and 96-bit MAC algorithms.
  • The remote SSH server is configured to allow either MD5 or 96-bit MAC algorithms, both of which are considered weak.
  • Audit flagged hmac-sha1
New to NetApp?
