C3 Tx discards and Frame timeout due to hardware issues
Applies to
Brocade Fabric OS
Issue
errdump -a
logs frame timeout, stating which port received a frame (rx) and where it cannot be transmitted on (tx) along with loss signal and oversubscribed alerts.
2022/02/09-22:31:04, [AN-1014], 2266, SLOT 2 | FID 128, INFO, NFAB1, Frame timeout detected, tx port 9/7 rx port 9/27, sid c8f907, did 678740, timestamp 2022-02-09 22:31:04 .
2023/12/23-10:47:16 (IST), [MAPS-1003], 274485, SLOT 2 | FID 128 | PORT 11/8, WARNING, switch, IB_INFINI_3185_W_N3P6, F-Port 11/8, Condition=ALL_PORTS(PORT_BANDWIDTH/NONE==OVERSUBSCRIBED), Current Value:[PORT_BANDWIDTH, OVERSUBSCRIBED, (TXQL=914 us, TX=72.8%) ], RuleName=defALL_PORTS_OVERSUBSCRIBED, Dashboard Category=Fabric Performance Impact, Quiet Time=15 min.
2023/12/18-01:35:43 (IST), [MAPS-1003], 270764, SLOT 1 | FID 128 | PORT 10/21, WARNING, switch, Nimble2_U_N2S3P1, U-Port 10/21, Condition=ALL_PORTS(LOSS_SIGNAL/min>5), Current Value:[LOSS_SIGNAL, 8 LOS], RuleName=defALL_PORTSLOSS_SIGNAL_5, Dashboard Category=Port Health, Quiet Time=None.
porterrshow
shows link failures, link resets, c3 discards txand frame timeouts related error counter incrementing.
/fabos/cliexec/porterrshow:
frames enc crc crc too too bad enc disc link loss loss frjt fbsy c3timeout pcs uncor
tx rx in err g_eof shrt long eof out c3 fail sync sig tx rx err err
391: 45.3g 3.4g 0 0 0 0 0 0 0 43.1k 5 0 5 0 0 43.1k 0 0 2.5k
sfpshow
indicates low receive power
Port 391:
RX Power: -8.1 dBm (155.8uW)
TX Power: -3.0 dBm (500.6 uW)
sfpshow
indicates Rx & Tx in optimal range -
portshow
indicates the remote device has resetted the link more than the local port sent OFFLINE primitives out
portshow 391
Lr_in: 133 Ols_in: 5
Lr_out: 7 Ols_out: 6
