Two FC ports disconnected and not connecting to ONTAP node
Applies to
- ONTAP
- FCP
Issue
- ONTAP node became disconnected on two target ports; no target side troubleshooting has impacted the state
- Ports have experienced credit loss and subsequent resets with increasing frequency in the last few months.
- Issue gets temporarily fixed, when a node reboot is performed.
Examples:
Switch:
CHASSIS, WARNING, BrocadeG610, Link Reset on Port S0,P2(19) vc_no=0 crd(s)lost=6 auto trigger.
ONTAP:
fct_tpd_work_thread_0: scsitarget.ispfct.cttimeout:debug]: FC HBA 0e nport 2031 timed out while transmitting common transport frame of type 0x1 and command code GIEL.
fct_tpd_work_thread_0: scsitarget.ispfct.cttimeout:debug]: FC HBA 0e nport 2031 timed out while transmitting common transport frame of type 0x1 and command code GFN.
fct_tpd_work_thread_0: scsitarget.ispfct.linkBreak:error]: Link break detected on Fibre Channel target adapter 0e. Firmware status code status1 0x2, status2 0x7, and status4 0x0.
fct_tpd_work_thread_0: scsitarget.ispfct.cttimeout:debug]: FC HBA 0f nport 2044 timed out while transmitting common transport frame of type 0x1 and command code RFT_ID.
fct_tpd_work_thread_0: scsitarget.ispfct.linkBreak:error]: Link break detected on Fibre Channel target adapter 0f. Firmware status code status1 0x2, status2 0x7, and status4 0x0.
fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0x1022 MboxStatus2 0xa1
fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0xfffe MboxStatus2 0x2
